Vibration with 22s
Have a 2016 with the 6.2 with max trailering and recently put the gm 22s on it. I had noticed a slight vibration of some sort when I had the 20s on it but now I really feel it with the 22s. I know there's countless pages of vibration related threads but this seems somewhat different than what I've been reading. It only occurs roughly between 40-48ish. Once you're above or below this range it's pretty smooth. To me it kind of feels like the rear suspension is hitting a frequency and causing the rear to shimmy sort of like a flat spotted tire. If it had a flat spot though you'd feel it at all speeds. I don't feel like it's the rims or tires causing it since I felt something similar prior with the originals. I think being there's less sidewall and the tire is stiffer it's amplifying what's going on. The tires are the Bridgestone dueller alenza plus which are rated pretty good in reviews. I've tried adjusting the pressure to see if that would help any but didn't notice any change. I may see if I can get the place that put the tires on to road force balance them just to eliminate that. These trucks are supposed to have heavier springs and different shock tuning with the max trailering but the rear seems pretty mushy. My dad has my old 2013 with 20s and the rear on that is super stiff. Granted that's got the sport suspension since it's only 4x4. I just figured these max trailering would be a lot stiffer. I may try to either put some weight in the back and see how it acts or try to do something with the springs to change the spring rate. I've read about some guys using the spring clamps. Anyway just curious if any of you guys have had a similar experience and if you've pinpointed the problem.
Thanks
I have 22'' on my 14 , they wouldn't take small pot holes or ruts in the road very well you could feel every one when you go over them. With 22'' on you have the small profile tires which I feel are the reason for feeling every bump on the road. So I had HD Bilstiens installed front n back and it pretty much stop all the rough bumps you I felt on the road . I never had the vibration that you describe thank God .
Had the wheels roadforce balanced today and now difference. Weren't really off as it was anyway though. Figured I'd try something when I got home. I put my old wheels in the bed for some weight on the rear axle. My suspicion is that there's something weird going on with the suspension and the shocks aren't actually doing much dampening. I think this wheel setup is a little heavier and it's causing the suspension to hit some sort of natural frequency. I took just a quick ride with the extra weight and it seemed pretty smooth. Need a few more miles though to tell for sure. Does anyone know if GM puts different shocks on trucks that have the 22s? I have the max trailer I got suspension but the rear is really soft when comparing it to my old 2013 that had the z60 setup. I check the shocks and don't appear to be leaking. My uncle has the same exact truck and his is just as soft.
  • 1 month later...
Stock shocks suck, I can take off my 22's with a street tire which vibrate and put on a set of 17's Nitto G2 and smooth as glass.
I think the larger wheels just compound the vibration issues already present and that's what stopping from installing the Wilwood brake kit I have, wanting to go smaller wheels.
I'm pretty sure it is the bigger wheels. Had a very slight shimy with my 20s but it's way worse now. Never had the vibration around 70 like a lot of people have though. Mine is around 40-45 and it comes and goes at different times. Smaller/stiffer sidewall is the culprit no doubt. To me just feels like the rear axle is shimmying. I'm just thinking the suspension is amplifying the affect because the shocks are so shitty and mushy on these max trailering trucks. If I get on the back and bounce it it's like it's almost only springs.
Z71 4x4, but I put Bilsteins on front (set at stock height) and rear after 200 mile ride home from dealer.
If you're thinking axles see the long post that is pinned up top. One guy has replaced his axles and solved his problem. I'm venturing down the axle swap path as well, but may just replace the whole rear as I'm looking to change gears and put a true posi unit in.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 1 Anonymous, 608 Guests (See full list)
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
