Stalling periodically
Im starting to develop a studded/stalling issue when cluch is engaged and turning or stoping
I have zero ideas on what it could be
Change the distributor cap. (and plugs and wires if you have not done so lately) Take a pic of the carbon tracks on the inside of your old distributor cap so people will understand how common an issue this is.
