Wet Carpet in Back of Suburban
The carpet in the back of my suburban gets soaked for some reason. It's not a leak. I did a thorough leak test. All the way across the very back of the truck and about 2 feet inward. I put it in the sun on the weekends with the doors open to dry it. I don't know when it started.
Any ideas of why this happens and how I can prevent it.
Had the same problem with my tahoe. I had a bunch of crud stuck behind the weatherstriping for the rear barn doors, cleaned that out so the water can flow away properly and haven't notice the problem since.
Maybe that will help
  • 4 weeks later...
Do you have Dual (rear A/C) ?
you may have a blockage in the drain for the rear A/C if it overflows the water has to go someplace.
Ditto... I agree...
If you have rear air then the condensation should drip out behind the right rear tire. If you don't see water drippeng from there when the rear AC is on, then you most likely have a clogged rear drain tube...
  • 3 weeks later...
My problem came back... it apparently wasn't the rear weather strip. :confused:
But I found another possibility tonight, There is a 2" hole directly above the rear wheels. The one on the drivers side has a plug in it the one on the passanger side is missing. This could be why my interior gets wet under the carpet in the rear passenger side corner.
You may want to take a look in your wheel well too.
    • 3.19 @ Kroger’s in Montgomery Tx
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
