antenna question
RP53
This short 6 3/4" antenna is the best performing short antenna we have yet to test. It will almost scan in as many stations as a 21" antenna.
How does this 6 3/4 version hold up in a car wash
Honestly, in our experience no antenna is 100% car wash proof. With having the hands on testing of our products and others our 6 3/4" antenna is at the top the list on the car wash durability scale. The smaller the antenna the longer the antenna will last through car washes. Generally then with a smaller antenna you'll have the issue with loss of reception but the 6 3/4" antenna I feel should be a factory application antenna. Hope this helps with your question.
TheAntennaSource
I actually moved the whole antenna to inside the engine bay. I look at it like an eyesore. Me just being me. I wanted it to look sleek. Plus I don't like that thing flailing around on the highway.
In the end, I loved that I moved it. It did impact the clarity. But not by much.
I agree with monkeymouth, I relocated mine yesterday. there is a thread about it and there is even a rubber plug in the box to cover the antenna hole, If you have skinny forearms its about a 20 min job :) No more antenna showing and if reception is reduced, it's very minor.
Took mine off and threw it behind the rear seat! With all the voices in my head I don't need any from the radio.
USB supplied music or Sirius with no talking only. Can't stand advertising.
I put on a 9" version of this antenna, reception is fine around town but degrades quicker when leaving town.
I wanted to move the antenna under the hood, but can't find the plug to fill the antenna hole after it's removed. Anybody have a link to the one they used?
Open the tailgate, look on the inside side of the box, there is a round rubber plug right there. Fits perfectly
I honestly can't remember where I found the cap I used. It's been a while. That was the first modification I did to the truck.
I got the CravenSpeed Stubby antenna. Its only a few inches tall and I haven't noticed much reception loss. On my last truck I shortened the original antenna. A small amount of heat on the little ball at the end and you can pull that off, cut the antenna to whatever length you want then grind the end so it fits inside the hole in the ball and solder it back on, looks original just shorter
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 338 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
