Door Handles
2008 Sierra Denali - rear passenger door handle is broken, does anyone know where I can find the correct replacement?
Coby, it is a black with chrome handles.
FYI I did order the entire set of door handles from 1AAuto and when I got them it turned out they didn't fit my truck, this was the response I got from their Customer Service
QUOTE
Hello Robert and thank you for responding with the VIN #. Our VIN Decoder shows that your vehicle is a regular 2008 GMC Sierra Denali not the 1500 model as the parts were ordered for. These parts will not fit the regular version of your vehicle.
Unfortunately we do not carry the exterior door handle kit you are looking for.
UNQUOTE
I was not aware there was a regular 2008 GMC SIERRA DENALI - compared to a 2008 SIERRA 1500 DENALI - any info on that for me?
Also looking to know if you can help me with this.
The HVAC controls on truck didn't have a Exterior Temp when I bought the truck last year, I replaced the HVAC controls and the new one has an exterior temp guage in the screen - any idea if that is correct or not?
GM Part No.: 25960522
HANDLE
This part fits this location on your vehicle:
  • Passenger Side(INCLUDES 34-36)(CHROME)(PO HANDLE PKG)
This part fits the following vehicle options:
  • Fitting Vehicle Options: CK1,2,3(43)
Passenger Side
Replaced by:
20954848
I've ordered three, two from Rock Auto and one from Amazon. All were Doorman brand and all were hardly distinguishable from OEM. All are less than a year old but, seem to be doing just fine. After replacing three (and correcting a botched job on #4) I've gotten pretty good at it. I'm sure you have probably looked at instructions online so I won't bother with all that but, I will say to make sure you start pulling the door panel off from the top, inside (closest to cab) corner. Also don't forget to put the plastic access plugs (covers hole in door to access the bolts) back in place. Nothing sucks worse than realizing you forgot them after you have snapped the door panel back on. :banghead:
The ebay guy says they won't fit on my car and I couldn't find them at Rockauto any other suggestions
http://www.rockauto.com/en/catalog/gmc,2008,sierra+1500,6.2l+v8,3300379,body,outside+door+handle,1024?a=Referer+www.google.com+URL+%2Fen%2Fcatalog%2Fgmc
http://www.rockauto.com/en/moreinfo.php?pk=2346978&cc=3300379
http://www.rockauto.com/en/moreinfo.php?pk=2007122&cc=3300379&jsn=544
Same exact handles I used on my 2011. Use coupon code 5387936748131651 to get 5% off. If that code doesn't work, do a google search for "rock auto how did you hear about us" and you should be able to find one that works. They always have an active 5% off code.
