Fuel Capacity - 26 gallon tank
Dmf10e
I was pumping gas into my truck yesterday and noticed the pump "clicked" a little too soon. I always typically "top off" my tanks, but MAYBE a half gallon more if I'm lucky. Well I squeezed the handle ever so slightly so I don't get that rush of gas and it stop and I was able to put about 2.5 more gallons of gas, with no spill. Never have I had this happen before with any other vehicle, albeit, this is the first GM vehicle I've owned. Not sure if there is a reserve in there that takes a while to have it fill up or what. But this seemed very odd.
Has anyone else ever have this issue? I drive a 2016 4.3L LT 4WD (26 gallon tank).
no reserve tank. your gas pump must have just shut off too soon. sometimes they do that randomly if the gas is splashing around in the tube.
There is no physical "reserve" but every vehicle sold today has a substantial amount of fuel left even when the gauge reads empty to save idiots from themselves.
Fuel will foam when you fill up (diesel does this far worse) and conceivably you could get a bit more in by waiting for the gas to settle, but this won't happen be repeatedly topping off. And topping off can cause issues anyway.
I have noticed that some pumps fill a little too fast and will prematurely shut off before the tank is full. Just depends on the pump.
Sometimes mine will constantly cause the pump to click off. I'll have to barely squeeze the trigger and fill the tank very slowly.
Sent from my SM-N910V using Tapatalk
The trick is to have the nozzle slightly pulled out of the tank to fill, no premature fills.
It's happened on several different gas stations. I'll let it go until the first click, when I know its close to being full and then I'll slide out a bit and finish filling. Just seems like its not filling up all the way. Shouldn't be considered "topping off" when you can put another 2.5 gallons in the tank, which means it's not full in the first place.
Are you leaving the nozzle pulled out some. Ive had the same thing happen, and i found this to be the trick. If you're filling up from when the light jsut comes on, you should be putting in 20-21 gallons.
I filled up at a different gas station last night and . I did move it out slightly and it was a normal fill-up. Must have just been a few rare occurrences..
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,231 Guests (See full list)
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
