window switches 2007
How many separate switch units does this switch cluster actually contain? One of the windows switches is acting up. Trying to figure out how much it would cost me to replace. The joys of a new (to me) truck.....
Any chance this is the right one?
https://www.amazon.com/dp/B0010GG7YG/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1C7GANXTBEKU9&coliid=I1G3MUOXHNQQ13
That's the right one.
Let me show you the procedure...
Pull this trim piece off.....
Remove these 2 screws, 10 mm I believe.
You will be left with this.........
Then just pry switch assembly...........
Switches just clip in. This would be a great time to re-paint that panel, did mine looks way better than a panel that was attact by a raccoon.
