Would tuning solve my trans issues on my 6speed
BlackHawkZ71
Ok I noticed 2-3 upshift in drive or M it seems to slip or hang even when driving normally. I am the org owner with 78miles on her, now around 8k, with some heavy right foot miles. Also some days not as noticeable. every other gear goes on in, .
Slip it can be up to 600rpm
Hang it can be at least 3seconds until it engages.
I drive in M 98% of the time including downshifting.
No cel or anything
I haven't taken it to my dealer yet,
I have had a bad trans before on a 47re (dodge) blew the trans line 3 times and and it hated me, after rebuild turned the power up and still slipped (due to a defuel setting)
Had 11 ram with a hemi 5speed with 80k or so miles, and no issues
It could probably help quite a bit, but personally if you're still in warranty I would never use a tune to bandaid a mechanical problem.
Just get it fixed and then tune it.
You may have issues doing it the other way around
Ya i just wanted to see what the experts here thought, before i took it in. That just means cleaning out the whole truck ,wouldn't be that bad if the dang techs didn't try to steal anything! ...
I do remember reading about funky shifting in the 6 speeds not sure if my issue is related to that
Also not sure when this started either but its been going on for several months (got the truck in February or march this year)
I really don't want to take the truck in "oh its fine" and it not get fixed.
I am wondering if it's just the way the computer does in M? And the truck is fine i do know wot 2-3 shift is rough.
Drove around in drive yesterday vs M and never did get it to act up under light to moderate accl.
Would a batt pull help out or no?
Update did a wot pull today from 20-80mph and it shifted just fine in drive
Also my trans fluid was top of cold (trans temp 132* in neutral)
So this tells me that gm more then likely cant fix this and I should tune her, but would it solve my manual shifting though truck stays in M 99.9% of the time anyway,
Question is which tune company (terfica, hp or dialbosport) or should i wait a couple of years? Probably gonna wait anyway still buying other needed mods probably intake this Christmas?
I do accept the risk of tuning but want to make it less noticeable when i take it in for warranty work. I know the risk but i dont plan on pushing my 5.3 to its max like i did my hemi...
    nolankd
    nolankd
  • Who's Online   2 Members, 1 Anonymous, 438 Guests (See full list)
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
