2016 silverado Z71 snow chains
Z712016
What type of snow chains have you guys used? I know in the Manual it states that it is not recommended to use snow chains but I find it hard to believe that there isn't something out there that could be used. Please feel free to leave website links or recommendations of any type of chains that could be used thanks.
I think they try to discourage chains because of the damage they can cause if they come loose.
I would find a set of cables or chains, in the appropriate size, and fit them so you know they will clear.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
