Andriod Auto vs Apple car play
new chevy
I have a new 2017 silverado which I currently use Andriod Auto. Its time to upgrade my phone and I was wondering if anyone has and info
on which is better with the new chevy's Andriod or Apple
AA and CarPlay is software from Google and Apple. It should be exactly the same on all vehicles. Apple CarPlay in the various GMs I've driven is no different than the CarPlay in the VW owned by my employer. There are tons of youtube videos for both, check them out.
Android auto has a few more nice features like google search and the google now functionality, but I really prefer the CarPlay just because Apple has more control over hardware than google. 2 different android phones might run Android Auto a little smoother or rougher.
  • 2 months later...
If I were switching phones I would look much further than AA and Car Play. I am so used to android that if I try to use an IPhone I get lost quickly. I also think that Google Maps is superior to Apple Maps.
  • 8 months later...
I advise would be stay with android, apple is alot more proprietary when it comes to features.
    zibzer2
    zibzer2
  • Who's Online   4 Members, 0 Anonymous, 739 Guests (See full list)
