Window trim
tmo
Hello all,
Recently I removed my window trim to swap them out, but decided to wait and now I cannot reinstall the window trim where it latches with the clips. Any info on how to get these back on would be greatly appreciated!
did you break a clip when taking the old ones out?
Only 1 of them. I took off all 4 and none of them go on. But I wouldn't think one clip would even mess up the 1 piece that has the broken clip, because there is still 3 good clips on it.
There is a very small lip in the middle of each clip. You have to look very hard to see it. Usually those break off even if the rest of the clip is still there. Once the small lips are broken the window trim will never snap back down correctly.
Look here (Post #6):
http://www.gm-trucks.com/forums/topic/193531-window-trim-replacement/
I think somebody even found the part number for the individual clips so that you can order new ones.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 983 Guests (See full list)
