Leasing A New Truck
Thinking about leasing a new truck, either a Chevy 2500HD or Ford F250 diesels, although idk what the prices are for leasing. Thinking of doing a 2 or 3 year lease. Anyone know how much it is to lease per month, I live in Illinois too and will be using it for farm use.
I will give you what I know about this topic because I was a sales and lease consultant for Ford back in 2010.
My information may be outdated and the tax benefits, if they apply will be different in the US than they were in Canada .
First of all your lease payment will depend on the cost of the vehicle and how much cash you put down. Leases can be negotiated. You will really have to pick out a truck and find out what the dealer can offer you for lease payments. At the end of your lease you always have the option of buying your leased vehicle and this price is usually better than normal retail price for that vehicle. The main two reasons people lease vehicles is for a lower monthly payment or if you have a business your lease payment may give you an income tax deduction. You have a farm , you have to talk to a tax accountant to get the info on that. Most non business buyers are further ahead if they buy the vehicle and I always buy mine. Both vehicles you are looking at have solid resale values which is another reason to buy. The one example of a lease being better than a purchase is when a person finances a lemon on a long term loan, makes payments for 2 years and ends up with a vehicle that he owes more on than he can sell it for, what we call backwards on the deal. If that were a lease, he could turn it in and walk away.
Right now finance rates are so low, buying is almost always better but do the research and remember most leases have mileage restrictions. Some people feel more comfortable with a lease, just knowing at the end of their lease they can walk away or negotiate another lease. Good luck in your choice of buying or leasing.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
