Dash Cover. Anybody using one?
zal15lt
Hey All,
Just curious if any of you are using one of the carpeted type dash covers in their truck?
I see the Silverado Shop has them for $39.95 and was thinking about using one in my '15
to help protect the dash and with glare. Worth the money?
Thanks
I have not tried this. It is not a terribly expensive modification so I suggest you give it a try if glare is a problem. It won't hurt your truck!
I've always bought a dash cover. I live in Arizona so I try to prolong the life of my dash. Most get cracks or begin to bleach.
Keep the color dark so to avoid glare. $40 isn't bad at all.
