Sounds like the RCDLR is bad. IE the Passenger Door Switch.
You can find them pretty cheap on ebay just make sure if you have TPMS you get the correct PDM RCDLR
PDM US RFA = Non TPMS
PDM US RFA TPM = TPMS
Will this post is an education in itself, thank you for posting. I will have to research some of the terms you quoted but thats ok.
My one fob has been inop for many years. Elderly family member tried to replace battery and the case is in pretty poor shape, so $25.00 and two replacements has that fixed.
I will look into switch today or tomorrow, thanks again
Didn't even know the 03 Silverado had TPMS. Thought it only started in 05 and became law in 08. Also thought the RCDLR was part of the BCM in 03, I'm confused.
Edited by Coby7
You can add TPMS to the older trucks with the addition of the Correct PDM and programming. I have even removed TPMS from both the new and old body style trucks but for legal reasons I would never tell anyone how since its a safety and federally mandated after 07. To many people that want to sue for anything now days.
I only glanced at the thread and did not really look at what year he had. After posting I saw something in the tail end of one of the post that might be his fob being bad. I hope the new ones he ordered work.
As for keyless entry
03 up is not in the BCM its all in the PDM.
I guess I should add that when you have power door locks with key less that it does have its own calibration in the bcm. I flash BCMs off the car for plug and play and thats one of the required answered questions in sps before you can program.
If I enter the acronym PDM in the GM server search line for 2003 Silverado the only response I get is Pump driver module for a diesel truck. I'm trying to educate myself here so hang in there. Where physically is this PDM you're talking about located?
Its in the Passenger door lock module.
Here is all data from a 2003 silv.
https://postimg.org/image/v4re42o87/
Edited by SpartanAutoworx
Here is the sticker on the back of the switch i was talking about..
https://postimg.org/image/gvr7rxe6p/
New fobs should be here Monday at the latest, amazon says Sunday via USPS......doubt that.
So the pic is the PDM or RCDLR or whatever it is called in the passenger door? And, needs to be programmed not plug and play if I understand correct?
I sure am hoping new fobs cure the issue, lowest cost fix so far plus mine nearly 15 years old anyway and one has nor worked for years.
thanks for posting
The PDM Is the RCDLR.
As for programming GM SPS does have programming for the PDM what functionality it actually gIves I have no idea. A new one may need to be programmed but I've never had a new one in my hand. I have programed used PDM's on the bench to the correct Vin the truck it was going to be replaced in but noticed no difference in my testing from donor truck to flashed vin in the PDM.
Coby7 & SPartanAUtoworx:
We are back in business. New fobs programmed smooth and are functioning. The retailer via Amazon sent his business card and recommended I go to their www site for programming instructions. I had Coby's instructions but thought I better check their site. Only difference is they mentioned I might have to hold the Unlock and Lock buttons for as long as 30 minutes. Not even close, less 30 seconds. Both are programmed.
Now off to mend the instrument cluster once material arrives.
Thanks for all the posts and advice, I have learned allot from both of you and your assistance has been a HUGE help.
SpartanAUtoworx, Appears you may have some used parts and I see you are showing ST Louis area. That being the case you are a stone throw away from me and I will retain your posts if that is correct.
v/r
Butch
Your welcome! I believe SpartanAUtoworx also repairs clusters if you get into trouble....
Edited by Coby7
Yes, I seen he has a keen interest in many truck areas. I will keep him in mind since he is not too far from me.
Your little video really pulled all together. A faulty fob will trigger some test equipment, but at the end of the day its a dud. Hence, the test light at the retailer reading ok when it was not :-)
Now to resurrect my other thread on the cluster once I remove it. Many, many moons ago I use to do some of that work on radios, but I need to refresh the technique.
Thanks again
Yes, surface mount is a technique alright compared to through hole.
  • 4 years later...
    • The amount of storage in the rear seat area is huge. You can keep all your cycle gear dry and clean back there
    • Truck in fluid changes and investigate subtle shudder at cruising speeds.  Told them it felt like my ‘14’s shudder when AFM kicked in.   Dealer #1 :  You need a new torque converter.   6 weeks later, after causing other damages to my truck, I get the truck back.  Same shudder exists. New, more violent shifts and vibrations at low speed.  After choice words and a few more weeks of waiting for them to replace my running boards supports, I move on to another Dealer.   Dealer #2:  The cruising speed shudder is DFM.  (I didn’t realize truck had it.) The TCM/ECM needs updates.  Updates will solve all vibration issues.   They perform updates, truck seemed ok in lot.  Not a mile down the road, SERVICE BRAKE PAD MONITOR. Dealer #1 stated brakes were at 4mm.   took truck back to Dealer #2, rear brakes at 2mm and less than 1mm.     New pads/rotors on rear, new pads up front.   truck seems good. Toggle through menus, brake monitor system is disabled.  Huh?  Why? Turn that sucker on : SERVICE BRAKE SYSTEM!     will not reset manually, automatically, or even after pulling negative bat cable for 30min.     Could the TCM/ECM updates the culprit?    A torque converter diagnosis for a “normal” shudder and now I’m thousands in the hole and the truck still isn’t right!  Beyond pissed.
    • Your right on. 👍🏻
    • Seats matter a lot.  I would start there - good advise here.  I had a 2018 LT Colorado before my 2026 LT Silverado, and the seats are so much better in the new one it's not even a contest.  That was one thing I always hated about the Colorado and I owned two of them spanning 10 years - but I did it so I could park in the garage mainly.  Now I have a much larger property and a huge barn so I have plenty of parking options and a full size is more useful for maintaining the property and current hobbies as well.  I wasn't evenb thinking about the seats as part of the reason for the move to the Silverado, but after two back to back 700mile road trips I am sold on the LT seats w/ leather 100%.  The other LT features are also nice - one thing I really like is the power rear window on the back window by the bed.  And the lighting in the bed is also very nice to have - I doubt that comes on the lower models.  Power tailgate - also quite useful - it's a heavy slug!  What else - I could take or leave the screen - but heated seats and steering wheel and cruise control on the steering wheel is very useable - I would never want to live without that.  Even the colorados had that.
    • I think the ship has sailed on the fuel injection type - everything is getting direct now.  Does it help with mpg?  Not really and nobody buying a HD truck really cares anyway.  But that is what it is at this point.  Piston rings is something they may well adjust over time to get them right.
