Grinding on right turn
jflan23
My '14 sierra 5.3 has a grinding in the drivers side front while turning right. Now, the odd part is it happens about half way between straight and full lock, it goes away if I turn more or less.
Started when I put new tires and rims on (stock gm wheels and tires from a midnight edition silverado). It has remained the same after I put fox 2.0 coilovers in.
Not sure if I'm thinking bearing, cv joint or ball joint. Any thoughts?
You can inspect your ball joint and cv joints for obvious signs. If the boots are torn for instance. Cock the wheel to the side and get a flashlight.
Probably bearing/hub. My drivers side is doing the same on takeoff and more so if I put the truck in AWD in the snow.
Sent from my SM-G930V using Tapatalk
  • 1 month later...
    tblt44
    tblt44
  • Who's Online   3 Members, 0 Anonymous, 477 Guests (See full list)
