What's not to love? Cost: ZERO!
For the end cuts,measure down from the top of the deflector 5 5/8", mark it and run your masking tape across to it from the center opening.
Happy cutting!
  • 3 months later...
I haven't done this yet but if it's like my jeep, it will cut easier if you take a heat gun (or hair dryer) to it, just ahead of your razor blade.
Yep, noticed that but, I found it much easier with just a blade. And less messy.
  • 5 months later...
Looks great and def cheaper than $350-$450 for a PPV deflector!!  I would've gone maybe a little higher even.
BigBlue what did you use to deburr all the plastic stuff from the cuts?
Everything I used is shown in the photo.  The cheezegrater and sandpaper block smooved it all out.
By the way, that mod saved me some bucks the other day when I pulled up to one of those downtown gutter curbs and still dragged a little.
Edited by BigBlueLB756
This tool works great - took 10min...680bc6e0d683a250e976b6ebc646df96.jpg7900b46bee91f3c84a33e2e6efb60325.jpg
Sent from my SM-G975U using Tapatalk
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
