Softer ride
Damn, do you do a lot of heavy off-roading or something? That seems like an inordinate short life for shocks. I had a jeep with 37s on 17 inch rims, a heavy winch etc and beat the hell out of that thing off road and could get at least 30k on shocks. What about the Fox 2.0?
I'd say switch out your wheels if you want a better ride. Shocks will only make a little difference if you keep the 22's on. You could probably sell the 22's and pick up a set of factory take off 20's or 18's and pocket some cash.
I've been riding 22's on my rides for many years and have tried many different shocks. They don't make much difference with all that extra weight. And when they do help, I find that they only last so long before they need to be replaced again - like 12k miles. The one exception are the MRC shocks that come on the Denali. I had a 2014 Sierra with 20's and standard shocks and now a 2015 Denali with 22's and MRC. The 2015 Denali with MRC rides better. I was shocked - pun intended!
The 22's I had on that 2003 Yukon were very heavy - like 100 lbs a corner. I found that the rears held up well enough, but the fronts took a pounding. They weren't designed to handle that much weight bouncing around. The fronts were so small compared to the rears. I never tried anything more expensive than Bilsteins. Something like Fox's with remote reservoir would have probably been much better suited for the application.
  • 8 months later...
I vote tires, different shocks will control the motion of the suspension more, but will not soften the spring which is the main determining factor in soft vs. stiff.
Will a leveling kit soften the front spring? Doesn't a 2 inch plate get installed above the spring? I would think that would stretch it out and give you more spring travel.......or am I thinking about this the wrong way?
Sent from my LG-H932 using Tapatalk
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 511 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
