Chevy Silverado 2500 2005 breaks
I have a 2005 Chevy Silverado 2500 i replaced the break lines and only can git fluid to the front passenger tire fluid giting to the abs box but not coming out ive bled by putting 20 psi in the Master cylinder and also tryed vy puping breaks still no luck. Also the abs box was replaced 4 mouths ago so I thought it went bad so i took and replaced it again under warranty and still same problem can eany one help thanks
Did you try cycling the ABS motor with the TechII as per the procedure?
If you aren't getting brake fluid out of the abs controller, there is a problem with getting brake fluid into it, as even if the abs controller completely fails, you still must have brakes.
1. Did you bench-bleed the master cylinder?
2. Does brake fluid come out of both input lines to the abs controller if you disconnect the lines and press on the brake pedal?
3. If yes to 2, then does brake fluid come out of all 3 outputs of the abs controller if you disconnect the lines to the wheels when you press on the pedal?
4. Are you sure you put all the lines in the correct ports of the abs controller?
FYI
Break: separate or cause to separate into pieces as a result of a blow, shock, or strain.
Brake: a device for slowing or stopping a moving vehicle, typically by applying pressure to the wheels. :happysad:
FYI
He might be French like me and often mix these up like there and their or tough and though or worst yet live or live.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
    • Great video. I almost want to reserve one now.
    • I traced the atf cooling system in my 1500 and it comes out of the transmission, into the bar/plate liquid/liquid heat exchanger, as stated above.  Then it crosses over to the external thermostat/bypass and then  to the aux cooler in front of the main radiator.  Hence, on this routing, the PPE thermostat bypass eliminator is an $85 piece of bling that does nothing for reducing atf temps on this truck.  I think I'll temporarily clamp a needle nose vise grip on the coolant feed hose to the bar/plate cooler and see how much the atf temp drops.  With the use of ULV trans fluid, I'm not convinced running the trans cooler than OEM spec is going to be detrimental to the life of the transmission.    I found this interesting on the Dana/Long site stating that they make transmission cooling/heating bar plate heat exchangers.  I worked with Dana/Long on a few projects when I was at the gas powered fun factory. https://www.dana.co.jp/downloads/PTG/Long/Dana_TOC_SpecSht.pdf  Bar plate heat exchangers are just a stack of stamped parallel path fluid channels, assembled and vacuum furnace brazed to make the final assembly.  Want more cooling/heating, just stack more plates until you run out of package space.   Anyway, thanks for the info, much appreciated.
