On 7/28/2018 at 1:17 PM, Levahj said:
Kyle - I'm determined to get Auto Climate Control in my 2015 Silverado I just picked up.   Thanks for the detail on how you were able to accomplish this.  I have everything on order now, down to the molex connectors that are needed in your description above.  What I cannot find is the wiring diagram of the X1/X2/X3/X4 connectors into the Control Module.   Can you please let me know where you found that so I can grab it .   BTW, my new control module 13591693 has J1,J2,J3,J4 not the X....   I assume your had it as well?  And the driver upper and lower duct temp sensors - where did you mount them?
You have to find them in the upfitter electrical wiring manual which is free online, the J should correspond to the X fittings, they will just be listed as X in the manual. If you give me some time I can try and find the specific wiring diagrams related to the connectors.
Not sure if this link will work, but this is it:
https://www.gmupfitter.com/files/media/photo/578/Sierra_Silverado_Electrical_Body_Builders_Manual_Service_Manual_2015_en_US.pdf
Edited by Harlech
  • 11 months later...
Hello Kyle,
I am interested in the HVAC mod for my 2017 WT Double Cab (midnight edition).
The truck has the light sensor in the dashboard. Would I need the additional sensor?
Will it mount along side of the existing sensor? Also I have purchased the HVAC control
for a 2017 High Country  #84173748 w/ATC. I installed it and it has full "manual function" with
the exception of the last blower Icon being active on the IOB 7" screen. It looks like the Dash Sensor
and Temp sensor are the same Part Numbers as your install. The ATC Module I am purchasing is part number
84237325 also for a 2017 High Country with ATC. Would you be willing to assemble the required plug ends and terminal
wire harness for me. I have trouble with the crimping operation due to nerve damage in my hands. I will of course pay
 for everything and your time. I have successfully installed the "Heated Wheel" upgrade along with Pgambola wire harness.
My next mod after the HVAC ATC will be the conversion from my "IOB" 7" infotainment center to the "Denali Cluster". It looks like
I'll have to replace the entire HDMI, Screen, Radio etc to realize the Denali upgrade.
Also are there specific markings for the temp sensor for the ducting such as a circle or molding mark for install?
Thank you for any assistance and information you are willing to share.
Love your engine mods on your truck and your vids. I sadly have the lowly 4.3L in my truck that will stay stock.
  • 5 months later...
First off want to say thank you for all this way to knock it out of the park. I have a 17 Silverado are the part numbers the same? I know gm likes to use the same modules for what seams to be decades but when I'm looking up the part numbers I see that they seam to end at 15 for year range
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
