Recently Purchased 6.0 Misfiring
This is my first post on the forums here as I just bought a 2003 Chevy Silverado 2500HD with the 6.0 engine. The truck has 206,000 miles on it. I bought the truck off of a friend of mine who is a fleet manager at an electrical contracting company, so this truck has primarily highway miles. The truck was recently worked on before I purchased it, and I have the receipts from the following work:
  • Replace battery and alternator
  • Replace PCM
  • Replace brake lines
The truck is in surprisingly good shape, even with 200,000+ miles. A few days after purchasing the truck, I started getting a flashing CEL during driving. The flashing CEL goes away when I return to an idle, and sometimes will go away when I run the engine in the 3,000+ RPM range. I scanned the codes, and found two active codes:
  • P0300 - Multiple misfires
  • P1637 - Generator L-Terminal Circuit
Can anyone give me some insight on how to further diagnose the source of the problem. I've been searching the forums, and I plan to replace spark plugs and wires. What else should I be looking at or checking, and how can I check it?
Totally clean the whole throttle and plates with Throttle body cleaner, dont miss a thing, then get some MAF cleaner, and clean that, then try it after clearing codes, Then you may want to mist starting fluid near intake and test for a vacuum leak . Good luck
I agree with Formulabruce. At this mileage, the intake and intake sensors are sure to be gummed up. Cleaning the throttle body and plate and IAT and MAF sensors may alleviate some of your symptoms.
DEWFPO
Thanks, guys. I will clean both the throttle body, the MAF, and will probably just go ahead and do the intake gasket since it is a known issue.
Should I do all of the above before looking into plugs, wires, coils, etc?
Intake is plastic ( no fuel) and can bend some, I would , and have done it on a few trucks, the simple stuff first, involves Cleaning. Coils and or wires last. Plugs? make SURE you use a COPPER Never seize on them. I recommend the Original type Irridium plug ( yes the more expensive 100K plug that retains its Gap)
Over the weekend, I cleaned MAF and throttle bottle, replaced plugs, wires, and intake manifold gasket. Still throwing the P0300. I did a little more poking around the forums here, and discovered that there is a crank relearn procedure that must be done after installing a new PCM. I called the guy I bought the truck off of, and he gave me the name of the garage that did the PCM install. I called them, and found out that they never did the crank relearn after replacing the PCM. I have an appointment tomorrow at 1:00 to have the crank relearn done. I'll report back tomorrow with results. Thanks for everyone's help and support. So glad to have the resource of this forum.
Having same problem with my 2002. Feel mine is top end damage.... but try the crank relearn first could solve your problems with the new computer being installed and the relearn not being done.... check your valve springs after they can break and find out what cylinder it is. These engines will read multiple misfire when it is really only one due to the trailing cylinder getting a bad misfire reading.
Sent from my Z981 using Tapatalk
Sorry for taking so long to get back on here, but I wanted to report that the crank re-learn DID solve my P0300 misfire issue! The relearn took less than 5 minutes on their Snap-On scanner. The scariest part of the process was when they had to hold WOT for what seemed like forever to get the relearn to take. 6,000 RPMs on these engines sure do sound intense.
Anyway, for anyone else out there who is getting this code, but the engine otherwise seems to be running fine, you may want to look into the crank re-learn. My truck has never run better.
That re-learn process seems ridiculous to me, I wish there were a better way to do it. My crank sensor went bad a year ago, I popped a new one in and did NOT re-learn it. 7,000 miles later, haven't had an issue
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
