Hard Starting When Warm
Hey everyone, so my 07 Sierra NNBS 5.3L Flex is having trouble starting when the engine is warm. If i start it in the morning when its cold it starts fine but if I start it then turn it off and let it sit for longer than like 30 minutes it cranks for about 4-5 seconds before starting or it will start and stumble then go back to normal idle right away. Last week I replaced the injectors and today I replaced the pump with a new replacement AC Delco pump and I am still having the issue. There is no Fuel pressure regulator on this and the filter is built into the pump so as far as the fuel system I dont know what else it could be. Is there something I'm missing here? Any help is greatly appreciated.
  • 2 years later...
Did you check the fuel pressure?  Unfortunately, new parts don't necessarily mean properly functioning parts.  You may also want to look at the IAC, TPS and clean the throttle body.
