2015i GMC 2500 SLT 4X not working right
Had to move the truck after removing all the wonderful snow that was dumped on us today...I put in 4XH and pulled out into the unplowed street and got stuck. Noticed the 4XH was not lit and truck was stuck and slipping and had NO power. Would not go over 8 MPH while wheels were slipping. Redid the switch to 4XH and light came on finally and truck moved back into the driveway.
Question is I guess the 4XH was stuck or frozen but why no power to move the truck? Gas 6.0/ 6 speed. Will the truck be good to drive tomorrow as the wife will drive it to work?
Sierra Boy
only shift while moving from 2 high to 4 high and back ... and front wheels straight
if you were stationary the electric shift parts may hang up ...
also no spinning the tires during the shift
even 1 mph is enough for the shift
I moved the truck 30 feet after I put into 4XH...never in-gaged. But why the no power during the slip? Once it went into 4XH finally it went forward then backward into the driveway. Under stand that it was cold and maybe had to unstick to work.
I was moving gear select back and forth trying to get to move in the unplowed street and that is when the power was lost. Once 4Xh was in-gage it moved fine. Is there something on the truck that drops power when it slips when NOT in-gaged in 4XH?
Sierra Boy
Thanks...that's what it seems like it did. Once the 4XH in-gaged it went into reverse and moved. I did not drive the truck any and guess I should in the morning so the wife is safe and the truck won't break down.
Thanks
Sierra Boy
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
