Rear 3 inch block different length shocks?
I have a 2014 Sierra z71 package. It had a two inch block at the rear now. I want to add a 3 inch block in order to leave things out. I carry I bunch of work stuff and I have a camper shell on the back so have a bit of a negative rake.
If I add the 3 inch block (net +1 inch lift) will I need to get a different length shock or will the Bilstein 5100's I have work ok?
Thanks in advance.
I have had 3" blocks on my stock shocks in my 2010 for over 50K miles now with no issues
Thanks in advance.
Hey bud, if you are dead set on using the blocks go for it it should be okay, you will find out pretty quick, but my suggestion would be to add a set of air bags to help level it. They will give you a better ride and level truck and when you pull a trailer you can level for that also.
Sent from my SM-G930V using Tapatalk
That's really not a bad idea. I am just about to add a compressor and tank in the back as well for general use. That would make the most sense.
Good advise
Man there is a bunch of Mississippi up in this thread! CSMDavis are you just on every single forum on the interwebs? This is Garland btw
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
