Anyone ever install a door keypad?
mnm99
I know some may say it's a F**D thing. I have a free $100 coupon when I bought my truck. I can't count how many times I went out to my old truck in the driveway just to get something thinking it's unlocked and not having my keys on me. This would be pretty cool. Anyone ever install one? I think the dealer has to program it.
http://vipadi.com/pdf/new-products-pdf/february-2017-pdf-keyless-entry.pdf
I just used the coupon yesterday for this. It hasn't come in yet, but yes the dealer has to program it. I haven't decided where to mount it yet. Some guys put theirs inside the gas cap door. I'm not doing that. I'm interested to see if anyone has installed theirs above the handle like it suggests.
Sent from my SAMSUNG-SM-G920A using Tapatalk
