The real issue is what was he doing on his phone? Hopefully, he pulled over and stopped.
Ever heard of Bluetooth? You know, that hands free device you can use to take phone calls.
Sure have. Also heard TODAY about a 71 year old grandfather mowed down at his mailbox by some airhead texting on a phone. You think maybe that's the sort of deal I'm referring to?
No, not at all. Maybe you should re-read the OP's post, he said he took an important call.
And that can't be done while driving?
My point is if he accepted a phone call through his Bluetooth, while driving, he did nothing illegal. Therefore, your pointed comment at having him pulled over and stopped was a bit excessive. Especially considering you contributed nothing to his actual question.
I agree that texting and driving is stupid. For your information, my cousin's husband just got rear ended last week by some dumb kid doing just that. Thank God their 4 month old was not in the Jeep.
  • 4 years later...
I'm pretty sure I just drove 4.5 hours to Philadelphia in 4HI yesterday.  Can't be sure though.  When I left to come back home today I noticed a grinding/binding noise when I took the on ramp onto the interstate and that's when I started looking around and saw it was in 4HI.  I don't think I hit it by accident leaving.  No idea when I engaged it last to be honest so I have no idea how long it's been in 4HI.  I tried shifting in and out of 4WD a few a times and it seems to be working fine.  The trip back home went well and transmission temperature was fine.  Hopefully these trucks are tougher than we may realize....
I drove around with 4WD on in twisty country roads for about 10 miles. Didn't seem to damage anything. I had a bad wheel bearing afterwards but I think that was from off-roading on a rocky trail earlier in the day (the reason I was in 4WD in the first place). I replaced the transfer case fluid and both differentials' fluid after for some peace of mind.
    RyGuy43
    RyGuy43
  • Who's Online   2 Members, 0 Anonymous, 414 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
