2009 Tahoe brakes pulsing
cutifulone
I have replaced the brake pads, rotors, and calipers on my 2009 Tahoe 2WD. The brakes are still pulsing when I attempted to stop. I hear a clicking noise too. I have had both stabilizer bars replaced. What else could this be?
Next place I'd check is the lateral runout of the wheel hub flange. If this is out, you could put one thousand rotors on it and it would never be right. Make sure all your hardware for the pads are installed. Excessive corrosion or rust buildup on rotor contact surfaces.
