Couple question's, abs light, PS, oil
Hey guys, I've got a couple questions about my 1999 silverado 5.3 4x4 z71 LS truck.
1. Ever since I got it a month ago, the abs light has been on, and the brake light comes on once in a while. PO said he had brakes done recently. Any clues on this? Bleed them and see what happens? Did change both front wheels bearings with abs sensors. Do I need to reset the light?
2. My power steering pump is whining at me at cold start up for minute or two, or until it gets some higher rpms. Should I replace the pump or...
3. The truck has 256,000 miles and is due for an oil change. What oil would you use? I'm thinking synthetic Mobil 1 10w 30? Gonna do the filter too.
4. Have a new rear differential cover and gasket to replace the old one that's rusted out. Any tips, or just remove old one, put new one in and fill with 80-90 gear oil?
Thanks!!!
1. Don't know, could be a number of things. check for rusted brake lines, bleed brakes and see if that helps
2. Check fluid and make sure its full, if ok, then check and replace belt if worn
3. Mobil 1 5W-30 is what I run with a Mobil 1 oil filter. Avoid the cheap Frams and the AC Delco E core filters.
4. Crack the bolts loose, pry the cover open at the bottom. Once drained, remove cover, scrape housing and remove all old gasket material. Install new cove and fill with Mobil 1 Gear Lube.
10w30 is fine. Actually on some levels, even better. 10w30, in the same brand a product line, will have a lower NOACK (burn off vaporization rate) than a 5w30. And unless you are dealing with cold that is lower than -30c / -23F, a 10w30 will do just fine and sometimes is cheaper to buy. At engine operating temperatures, a 5w30 and a 10w30 are the same critter. Only the cold start flow rating is lower with the 5w30. My 2006 Cadillac CTS that GM said needed M1 5w30 to keep it alive has been doing extremely well on a Pennzoil conventional 10w30, year round, for quite some time and has had far fewer issues than many with the LY7 3.6 engine. Plan on keeping that car for a lot longer.
I have been partial to Wix / Napa filters for long time. Especially the Wix XP / Napa Gold line which are the same filters. M1 is a very good filter as is the Fram Ultra. The latter should not be confused with the low end Fram's that had some issues several years ago. All of these filters use higher quality synthetic mesh media as opposed to a cellulosic "paper" media.
I have grown very fond of using 75w90 synthetic gear lube in all of my stuff. Got sold on it in the mid 90's for my heavy commercial trucks, and that is what is in the diff of every vehicle I have owned since. 80w90 is fine, but syn 75w90 does tend to hold up a little better and for a longer period.
1) Do you get any unwanted ABS activation? There's a recall on wheel speed sensor corrosion. Check and/or replace as needed.
2) Silly question - have you checked the fluid level? My '09 Impala was whining, and it turned out to be low on fluid.
3) I'd go with 10w-30 high mileage Mobil 1. The thicker cold viscosity won't hurt you in Florida.
4) 75-90 synthetic is what's recommended/required in your owners manual for the rear axle. That's what I'd go with.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
