5.3 changes over the years?
Does anyone know what changes have been made to the 5.3 during the years of production? The local expert (Thunder Racing) says the '02 and '03s seem to have more h.p. in stock form but don't respond to minor mods like catback, air intake, & reprogrammed computer as much as the earlier models do.
:D
Between the '99 and '00 model years (I think), they changed the cam in the 5.3 to the one used in the 6.0 . They gained 15 HP and some torque (can't remember the amount) just with that change.
'02, No EGR, air box has no baffles like '01 (sshotrods.com), the throttle body and MAF look like 80mm
What did GM do to lower the N0X levels with out a EGR valve?
No Baffles in air box, Did they change the size of the Box? the baffles help to reduce intake noise, How did they overcome noise ?
Same filter used?
For 04 the 5.3L goes to 290hp and 330tq. :D
100R1 Posted on Jul 6 2003, 10:03 AM
  QUOTE (Tucson_02Silverado @ Jul 5 2003, 01:19 PM)
Since no one is answering this one I'll refer to the LS1 and say they did it by changing the cam. I don't know when/how they did it on the 5.3 though.
99 to 00 they changed the 5.3 cam to a 6.0 cam to up the HP from 270 to 285
What is the difference between the regular air cleaner and the high performance cleaner that comes with the towing package?
i have heard the 2003 have 290 hp is this correct. and if this is true what did they do to make this happen because i would like to do it to my 01. thanks
:smash:
It's called the high capacity air cleaner. I believe it's because the filter element is much deeper (more pleats or fins) than a standard filter. It's almost 3 inches thick compared to a normal paper filter of around an inch or 1.5. If you would stretch it totally and lay the paper flat, it would be longer. It just means it can hold more dirt and go longer between changes. I have almost 12k on mine and i'm suprised that the headloss guage has barely started to move, and I haven't lost any gas mileage yet. I haven't decided on which cold air intake I want to go with yet.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 255 Guests (See full list)
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
