2016 silverado no a/c
A/c worked great all last summer on my 16 silverado. It's warming up here now, tried a/c twice in past week and let it run 10 plus minutes (70 deg. Outside) each time and get no cold air. I see lots of issues on 2014s in another post. Anything special about a/c problems on the 16s or anything I should ask the dealer to check when I bring it in?
Sent from my SM-G930V using Tapatalk
If it's under warranty...take it in. But I've seen lots of compressors tearing up at the clutch on the end of the compressor
Very common issue with the 2014-2017 trucks. GM has a new hose just released that is another attempt to correct this issue. Got a truck on schedule to get the upgraded hose next week.
Still under warranty, but always nice to know ahead of time if there are any bulletins out for things like the new hose you mentioned.
Condenser is the most common thing on the 2015+, hope you're not over the 36k mile mark.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
