2013 gmc serrera crew cab 80 .000 miles tranny quit no 3. 4 th no reverse towed to gmc dealer checked next day run fine with no problems no codes dealer drove 50 miles with no problems any one else having this or herd of this ?? dealer said they cant fix if cant find anything wrong
I had a Camaro that did that one time wouldn't shift up from second. Dad freaked out and said I couldn't drive it back to school. Sold it to a local guy who drove it for 5 years without a lick of trouble. Still a little miffed at him.. :-) if it's working I'd drive it. Maybe look at a fluid change soon if it wasn't done recently.
Sent from my VS987 using Tapatalk
yes i had fluid change about a 2 months back it is never had a problem before really weird ;;maybe a censer going bad ? i will pick up from dealer tomorrow and drive so if it does it again hope to be close to dealer so they can see problem first hand
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
