Pandora / Phone App
16 Sierra :
I am noticing a strange "glitch" that i am wondering if anyone else with a 16 Sierra has noticed. when i lauch the pandora app it will play "Most of the time" on the last station i was on no problem, however i am noticing now that if i change pandora stations the display says "Acquiring Pandora Radio" it will play the new station and keep playing songs it just says "Acquiring Pandora Radio" If I go to the "AM/FM Radio click any of my presets, then click back on the pandora icon it will show the artist / song etc.. and not say "Acquiring Pandora Radio". Same loop happens if i change stations on Pandora again.
Bought it to the dealer, they said there was a radio update and it was fixed. Went to the dealer picked the truck up and saw it was still doing it. Left it overnight got a call saying it has to be the app on my phone that other trucks do the same thing in the lot with other guys phones..
My 14 never had this issue anyone else seeing it? .... :bs:
I've seen it on my '15. Face it, this sh#t is not ready for prime time. I think it's the phone or app. Unless you update the truck (which rarely happens) and things change as to how it works then think about how often the phone and apps update.... All The Time. I got a new phone 3 months ago. Pandora worked flawlessly for about a month. Then it started having odd behavior. The truck didn't change but the software on the phone did. I just accept it and live with it. It may get worse. Our service manager just went to some meetings and was told because the phone and software advance so fast that GM can't keep up. It would help if all parties would stick to a set of standards but they think their way is better.
I think it's the app, I just recently started having issues with my aftermarket Pioneer radio showing Pandora stations too.
Sent from my SM-G930P using Tapatalk
  • 2 months later...
I'm having issues since I upgraded my phone from the galaxy 6 to the galaxy 8. My pandora app worked great in my GMC on my galaxy 6 but once I tried with my galaxy 8 and tap the pandora app, the app comes up with my station and list like normal but then immediately backs out of the app after 2 seconds. I've only been able to get the app to stay on twice since getting the galaxy 8. Not sure what you can do about this. Any thoughts besides just blaming software on the phone or pandora?
Sometimes mine does not work with the Pandora app on my touch screen. Ever since I put a pass word lock on my phone. If I unlock my phone first then hit app on screen it works every time.
    Gkistler
    Gkistler
  • Who's Online   4 Members, 0 Anonymous, 926 Guests (See full list)
