Is there a cheap ALDL code reader?
Simple enough question, I'm looking for a GM ALDL / OBD1 code reader that doesn't cost a fortune, and I'm not talking about one of those things that jumpers the pins and flashes the dash lights. Cheapest one I've found is ~$110, it does both OBDI and OBDII, as well as GM ALDL with a cable you buy separately. The scanner I found is the Actron CP9185, and it's accessory cable CP9127 for GM OBDI / ALDL
The reason I'm asking is I've got an intermittent check engine light, when it's off the truck runs and idles great, when the engine light is on the truck will idle rough, miss, and sometimes lurch forward when idling. There are so many new parts on the truck I can't begin to guess what's wrong, so figured I'd just buy something to plug it in with.
The short list of new parts is
Engine has been rebuilt, less than 30k miles ago I think
Throttle body
ECM
IAC
VSS
EGR
Distributor, plugs, wires
Many, many other sensors including the MAP sensor
Fuel pump, and filter
The only issues I know of are:
The ignition coil has not been replaced, I suspect it may be on the way out or in the very least a weak link in the ignition system. It also has a vacuum leak somewhere, brake booster maybe, can't tell until I get new calipers on and bleed the brakes.
So yeah, at this point I'd just as soon find a way to plug it in rather than chasing gremlins blindly.
  • 4 weeks later...
Guess no one has an answer, and that particular code reader has recently stopped being sold. East3021, if I knew the code, I'd look it up, I'm trying to find a code reader 'cause I haven't got patience to jumper the pins.
    mark2
    mark2
  • Who's Online   5 Members, 0 Anonymous, 648 Guests (See full list)
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
