1.5" body lift on 2017??
I saw where one guy put the '14-'15 zone 1.5" body lift on his 2017 gmc, anyone else do it?
I have a '17 with a 6" fabtech. Thinking abt adding the 1.5" body lift for added height.
Thanks!
Zone said it will be out soon for '17s, just got another email from them last week
You have to do a little extra cutting for the e-brake line. And drill a hole in the tow hooks and put them in upside down. also something about the tube for the spare tire doesn't line up perfect. I didn't do it but that's what my tech told me he had to do.
