Looking for the xm module location on my 2014 LTZ. Specifically where the xm antenna plugs into the module. I have a external sirus head unit that I paid for a lifetime subscriptions years ago. I would like to use the external unit and leverage the stock antenna. There are a ton of videos on how to do this but all show a 2013 which has the module behind the glove box. Is that where the module is for the 2014?
I should mention I have the 8 inch my link screen with xm installed. Just would like to use my xm head unit with the aux.
Thanks!
Directly behind the screen. AM/FM/XM radio and Onstar radio's both behind the screen.
  • 6 years later...
  • 7 months later...
On 5/23/2017 at 5:45 PM, Toolbox1 said:
Looking for the xm module location on my 2014 LTZ. Specifically where the xm antenna plugs into the module. I have a external sirus head unit that I paid for a lifetime subscriptions years ago. I would like to use the external unit and leverage the stock antenna check here. There are a ton of videos on how to do this but all show a 2013 which has the module behind the glove box. Is that where the module is for the 2014?
Thanks!
For your 2014 LTZ with the 8-inch MyLink screen and XM installed, the XM module location might vary slightly from the 2013 models. Typically, in 2014 models, the XM module is still located in the passenger side area, but instead of being directly behind the glove box, it might be under the dash or near the A-pillar. However, it's not uncommon for there to be slight variations in module placement even within the same model year, depending on the specific features of the vehicle. To leverage the stock antenna for your external Sirius head unit, you'll likely need to access this module. If you're unable to locate it based on these guidelines, consulting the vehicle's service manual or a professional installer might be your best bet for a precise location and advice on making the connection.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
