So far i'm 94% happy. (I think the rear shocks might be a bit stiffer than stock so it's a bit more choppy over hard bumps). Other than that the truck works like stock, steering is great. I just ordered their helper bag kit so I can tow my open trailer. I couldn't be happier with the kit, the truck is in the weeds and still drives like stock
Is there a revised kit because i may have to go this route to go any lower even though i hate the inez arms
I just bought mine this year, not aware of any updates but I guess it's possible
I've bought and installed the kit 5/7 on my 15 rcsb and really I like the kit. But I'm having issues.   Flip kit was easy, driver front went together perfectly, but from jump the pass side was off.  Im not sure what the deal is but we are working on it.  truck has 23k and never in a fender bender. The plastic knockouts were still in the alignment cams. Aluminium control arms and spindles. Cams are maxed and can't get the pass side to align. Driver was perfect.  but both tierods needed trimming to get the toe set.
Edited by RDietz9
I've bought and installed the kit 5/7 on my 15 rcsb and really I like the kit. But I'm having issues.   Flip kit was easy, driver front went together perfectly, but from jump the pass side was off.  Im not sure what the deal is but we are working on it.  truck has 23k and never in a fender bender. The plastic knockouts were still in the alignment cams. Aluminium control arms and spindles. Cama are maxed and can't get the pass side to align. Driver was perfect.  but both tierods needed trimming to get the toe set.
What brand wheels?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Inez wont align right unless you buy there 400 dollar upper arm    they are hacks that copy other people's designs
2 minutes ago, RDietz9 said:
I bought there whole kit.  Do they sell a different set of uppers?
Yes they do now.  They are for up to 9" of front drop
Wow.  I would like to be about 7/9 kit with an underbed notch.
Heres my other project:
Accuair Endo CVT E-level, full backhalf and 5.3 w/4l60
5 minutes ago, RDietz9 said:
also, I don't see anything about 9inch drop arms.
They make them. I have a buddy who is selling a set for stamped steel arms
stamped and aluminium use the same arms.  Cast is different.  what does he want for them?
Pretty sure they are around 500 shipped.  Id give them a call if you really want to go that route
