Vibration Repair #4
Just got off the phone with the dealership. I was informed that they are replacing a tire, balancing the tires, and installing cab mount shims to stop my vibration. What does installing a cab mount shim mean?
The body is mounted to the frame with (not sure of the material - maybe Neoprene?) rubber-like mounts. Shiming them means they are inserting a spacer of some sort to change the translation of vibrations between the frame and body.
Not sure if that will work on my truck (though I'd be willing the try it). My vibrations come trough the steering column now.
My vibration is all over... including the steering column. I'm hoping this fixes it but im not sure
Go ask the individuals doing the work on your truck. Have them show you and explain to you why and how they will do this repair. I would try the truck with the tire replacement and balancing prior to going ahead with additional work. My GM products have always been smooth rides but vibrations in other vehicles have always been wheel related! I find it hard to understand how some truck owners are experiencing vibrations that go beyond wheel issues on a new truck! If this issue could be isolated to a particular assembly plant, model of truck or date of manufacture then maybe it would be easier to find a cause!
Has anyone replaced their wheels and tires with aftermarket wheels and new tires and still have shaking? I want to buy some lightweight 18's to swap out when I feel like it. I believe there's something going on ( like the mounts) that makes these trucks exaggerate any vibration that's there..
Sent from my E6810 using Tapatalk
I had 20s that came with the elevation package and I swapped to 17s wrapped in 34s and I have zero vibration.
Did you have any vibration before swapping the wheels and tires? I really like the looks of the 20" wheels that came stock on my truck but nothing is worth a crappy ride. I'd like to see pics of your truck.. Always wondered if the 17"wheels would look ok with a large tire. Mine are 33.1" and on a 20 they still look small.
Has anyone analyzed a video to determine the frequency of the vibration? The frequency would tell you which driveline component is exciting the movement as the vibration would be equal to or a multiple of the component frequency.
Is there an app for that? Lol in all seriousness I've been trying to figure this out without the dealership. I've installed Bilstein leveling shocks and larger tires along with a tune so I don't want to hear their bull poop about it being what I've done. If I can locate the issue then I will tell them what to fix. You know.. Ya gotta do people's jobs for them quite often.
I think it would be easy enough to analyze the audio via a decent video editing program. Just need to count out the peaks of the thump thump thump sound and convert it to frequency, and then to rpm. If we know the sound frequency along with what gear the person was in and at what engine RPM we could determine exactly what rotating component is exciting the movement. Would also need to know the rear end ratio and which kind of transmission.
Mine had the vibration from day one at 74 mph and took it back 3 times and they balanced and balanced,replaced a tire,replaced drive shaft so I said hell with it.Went there two weeks ago for the seat belt recall and when I walked in he said hey we have a new balance machine and hired a tech to just do balancing can we try to balance your tires?Yes go ahead and they did.I left the dealer jumped on interstate and guess what?No vibration!!!!Ran it at all speeds and rode nice just like wife's caddy.So good luck hang in there I think they had a bad machine before.
I had vibration at 72-78 mph and it got better when I rotated tires the first time and then got worse when I did it the next time, meaning that one of the tires was out of balance and unnoticed it more when that wheel was on the front.
17s and 34s
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 491 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
