Zone 4.5 or 6.5 modifications.
Zone suspension lifts seems to be the most popular option for the 2014+ Silverado's and Sierra's, with that being said, have any of you guys installed any other suspension modifications to your Zone lifts? It would be awesome to get a list of setups that work in conjunction​ with our Zone suspension lifts.
Do you have aftermarket sway bars?
Do you have aftermarket front or rear shocks?
Do you have aftermarket front coilovers to replace the front spacer on 4.5 or 6.5 lifts?
Do you have aftermarket control arms for better travel?
What have you done to your already awesome Zone suspension lifts?
What works and what doesn't.
Anything else I missed would be appreciated.
Keep trucking guys!
Thanks.
I have the 6.5 lift. Currently running Bilstein 5100s for front and rear. Plan to go with baja UCA and change out my tie rods later. I love the kit.
If you want the front wheels to match your rear. Get a set of adapters. I am currently running Bora 1.75 in the rear wheels.
If you like the rally look than you can leave the kit as is. If not, look into a add leaf kit for the rear spring.
Keep trucking guys!
Thanks.
Only thing I did to my 4.5" kit was swap the rear 4" block for a 3". Only other think I think is really worth doing for a street DD is fox 0-3" COs and rear fox shocks
Which part number on the bilsteins for the rear? Also, the 5100's are adjustable right? Did you leave them at stock height?
Hello, the front I got the adjustable and set it one over stock. The rear I got Part Number: BSN-33-185569 to avoid using a rear adapter extender. This allow me to go over 6.5.
Great info, thnx
    Selfman
    Selfman
  • Who's Online   3 Members, 0 Anonymous, 372 Guests (See full list)
