Headlight clear coat peeling?
So my Anzo headlights look like the clear coat is starting to peel on the passenger side headlight causing a kind of haze. Is there a way to fix this? Like wet sand it all and reclear it? Or am I gonna have to bite the bullet and just get a new set?
No they are not under any kind of warranty anymore unfortunately.
What grit wet sand paper are we talking? I have 2000 grit at the house or should it be finer then that? Also where would I get 2k clear coat?
You can see the line just above the u-bar where it is starting to peel. Driver side is just under the projector.
I would probably start off with 1000 and see if that knocks it down. Go up to 1500 and then clear. You can get clear on amazon. I used the spraymax brand with good results before.
    tblt44
    tblt44
  • Who's Online   6 Members, 1 Anonymous, 553 Guests (See full list)
