2.25" FRONT LEVELING KIT AND 2.25" REAR BLOCKS
I as wondering I anyone had this set up in their Z71 Silverado or sierra? I researched and found the Z71 models has less rake than the other trucks. I cant really find much information on here about this set up I am looking at installing. I'm looking at a Ready Lift 2.25" front lift and adding a extra inch to the rear, this will be a 2.25" rear block replacing the oem 1.25 inch block.
Do I need to get rear shock extensions for this? or anything else?
Will this effect the ride and handling much? and how about the fuel economy?
I am told by my local GM dealership that this is ok and the warranty wont be effected.
If anyone got this set up in their 14+ Silverado/ Sierra could you post a picture of how the truck looks? and any information that might be helpful to me.
Thanks!
Thanks!
370 pages of answers and pictures for you
http://www.gm-trucks.com/forums/topic/153363-2014-leveling-kits/
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
