Traction Control, Stabilitrack, ABS... And more!
This is my first post. I have a 2012 half ton Silverado. I bought it used about 3 years ago with approximately 28,000 miles. The truck now has 87,000 miles. Never really had any issues until about 6 months ago my rear differential went out. Replaced that, everything is good. Now starting about a week ago the traction control, stabilitrack & ABS light appear on the dash shortly after I start the truck & put it into gear. If I have my steering wheel turned & drive forward or reverse the truck needs a good amount acceleration to go & and the tires like to spin as well. I have not found anybody else with the same problem. I'm new to the forum & would like to hear some ideas or fixes. And I would really enjoy avoiding the dealership prices! Thanks guys
-Matt
Since you're trying to avoid paying a GM dealer, take your truck to an auto parts store. Most of them will scan for error codes for free. However, their scanner may not detect all errors that a GM scanner will.
Or if you subscribe to OnStar, push the blue button and tell them to run a remote diagnostic and tell you the error code numbers.
Almost any problem that 'throws a code' will make the 'traction control and stabilitrak' service messages show up in the DIC; most of the problems have nothing to do directly with traction control or stabilitrak.
Once you know the error code numbers, then you can google it, use a repair manual, or ask the auto parts store how to proceed with the repair. I used to subscribe to alldatadiy.com online--it lists recalls, technical service bulletins (TSB's), and shows schematics and repair instructions.
Thank you! I know the traction & stabilitrak can be broad, but hopefully we can narrow it with a code.
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
    • Engine Wear and ISO 4406   1.) Cold Starts. 2.) High Particle Count. 3.) Low operating temperature viscosity and high low temperature cranking viscosity. 4.) Depleted AW, Friction and Acid packages.  5.) High engine load.    https://me.caltexlubricants.com/en_me/home/learning/from-chevron/heavy-duty-diesel-vehicles-and-equipment/The-Importance-of-Clean-Engine-Oil-and-Its-Impact-on-Equipment-and-Business-Performance.html   High particle counts have five sources. 1.) They are manufactured within the engine. Both wear debris and amalgamation of degradation products and combustion driven soot (worse in GDI). 2.) They are ingested via intake air. Ever hear the best oil filter is a good air filter? 3.) They are entrained in the fuel. 4.) This one is insidious. They are introduced in 'fresh oil'. 5.) They are introduced during the oil change.   ISO 4406 is the test that measures and quantifies the combine effects of all of the above particle related issues. You can mitigate your way into multiples of engine life by being attentive to them all.    https://www.hyprofiltration.com/blog/is-new-oil-clean   (from the link above)    [Quote] What Is the Recommended ISO 4406 Cleanliness Code for New Oil?   A good upper limit for new oil cleanliness is 16/14/11 (ISO 4406). Typical new oil usually has ISO codes of 19/17/15 or worse, which is far too dirty for sensitive components. This can be a major cause of degradation and premature failure. [Close quote].     Source of graph: Machinery Lubrication (GM Study)
