Baby Ink
MarkD
What do you think of this
25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
That is just wrong, wrong, wrong! :lol::thumbs:
Since you are not considered to be a legal adult until age 18, we have to look to the parents on this one. :flag:
If you're dumb enough to have your baby' ears pierced, then go ahead with the tat. IMHO, both are totally wrong.
Stupid dumb@$$ parents. :thumbs::flag:
Wrong, just plain wrong. Let's put a permanent mark on a kid who can't even use the toilet yet. I'm almost 21 and quite frankly I can't even think of a tattoo that I would want on me for the rest of my life. If my parents had gotten a tattoo on me when I was a little kid I would be ticked off.
How in the name of god can a parent do this to there kids?
Read the first line "Welcome to Baby Ink, where we believe that it's never to early to start expressing your unique personality through professional, high quality body art."
So who is expressing there unique personality? Not the kid, but the parent.
This IMO is a form of child abuse, and any parent that inflicts this on there child should be locked up.
Let the kid make his on choice, when he/she is of age.
I'd love to be walking around with Winnie the pooh on my arm, maybe at 6, but not at 30.
This is one of those times were they should require a license to breed.
my .02
Stupid dumb@$$ parents. :eek::)
Even worse. If you don't wear the ear ring, the piercing will close up by itself. Unless you are willing to go through the process, removing a tatoo is impossible. :)
Stupid dumb@$$ parents.  :)  :P
:) 100% MoJo.
But if you have enough money, time, and patience, laser tattoo removal is a way to rid yourself of the tattoo. Bad news, besides the cost, is the high risk of damage to the epidermis, thus increading the risk of getting skin cancer.
No thanks, I'll just stick to the tats that you can get in the supermarket, You know, the animal kind that you can get from the candy dispensers at the exit door for $0.25 ? :eek::lol:
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
