Adding amp & subs to stock 2007 GMC Sierra?
So I have a 2007 GMC Sierra 1500 Crew Cab. I don't have bose. How can I hook up an amp & subs to the stuck radio?
or what are some good wire harness' to install a single din &/or double din?
Yep there are also amps with line converters built in, you just tap into your rear speaker wire for signal
Sent from my SM-G930W8 using Tapatalk
Kicker Soundgate is pretty sweet. Not overly aggressive and sounds clean. They are designed specifically for your vehicle and is plug in play. With my stock radios I installed Infinity Kappa's in the doors with the complete kit years again and have never regretted it. I actually installed the complete kit on a friend's crew cab, who liked how mine sounded (minus new door speakers).
Complete with amp for door speakers amplifier and subwoofer:
http://www.kicker.com/PSICRE07
Just subwoofer kit
http://www.kicker.com/SSICRE07
  • 9 months later...
I'm sure this question has been asked before, but I cannot seem to find the topic in my searches, but has anyone hooked up the sub only to a non-Bose system w/aftermarket deck?? Kicker tech says sub needs 6 volts of power to turn on sub amp, and most aftermarket head units only supply 2-4 volts. I would think one could add a voltage line off the head unit to send more volts, like 12v to the Kicker to power it up & work??? Any help would be greatly appreciated!
For turning on the amp, you could always use a replay that would be triggered by the radio. Would 12 volts to the amp turn on wire work? If not, use a resistor to drop it to 6 volts.
I'm wondering why the remote wire from the deck to the amp wouldn't turn on the kicker??? I may call their tech support again & pic their brains. Thanks for the info starman!
    250.3k
    Tiffanyrose
    Tiffanyrose
  • Who's Online   5 Members, 1 Anonymous, 1,055 Guests (See full list)
