Got in the truck Sunday to go to church, and got the "Service 4WD" message in the DIC. It's in 2WD and the indicator light just goes off if in any position besides 2WD. I've used 4HI and 4LO a few times in the past and never had any issues. Did a quick search but the results were either for older 2500's or for 1500s. Didn't know if anyone up here has had this happen yet on the 2015+ 2500HD trucks. I do plan on taking it in soon and getting looked at.
I have it scheduled to be looked at next week. Any ideas would be welcome, though.
My old 04 2500Hd used to do this from time to time. I would guess 4-6 times in 12 years. I would shut the truck off and on restart the message would be gone and all worked as designed.
Once in a while I would also get the heater come on when it was 90 outside. Same thing, shut it off and restart all good back to AC. Haven't seen either on the new truck yet...
Damn Computers....
There was a TSB with something to this effect on the 1500's but not sure about the HD's. Sounds like the same problem, though. It was a switch/sensor issue and not an actual mechanical problem.
Hope to hear something late tomorrow afternoon or Wednesday morning. I'll be sure to share their findings.
They told me they had to order a new actuator. It should be in tomorrow.
Update: The 4WD Actuator was order Wednesday afternoon and was still in transit with FedEx yesterday. Hopefully it will arrive Monday and I will be able to get the truck early in the week.
Still under warranty? Hopefully this will fix the situation.
Yes, it's still under the B2B 3/36 warranty. At least for another year or 11k miles.
So, the service rep misspoke about the particular part ordered. No biggie. They had to order a new module for it. That came in and they went to program it, but after last evening and this morning, said that it wouldn't take the program. They are sending the "new" one back and having another new module overnighted to the dealer. I have the truck back now with the "Service 4WD" message and now a "Service Stabilitrak" message, as I had to have it for the next few days. They will call me when the module gets there and we will schedule an appointment to get it installed and programmed. Started to get a bit agitated, but realized that it's out of their control as far as a bad component is concerned. I truly hope that the new module comes in and can be installed and programmed correctly the first time.
Finally got my truck fixed. I had to take it back to them once the part came in, as it was no need for it to stay there when I could use it. As it turns out, the problem was cause by a corroded wire coming from the module. Apparently a rodent or other vermin nibbled at the insulation, possibly before I even bought the truck, and the wire finally corroded enough to break the circuit. All was repaired and it's driving like new.
Side note, a friend of mine was telling the story of test driving a new truck, and when they opened the hood they found that something had been having a field day with the under-hood insulation.
Had that warning on for 11 years on my '06 Silverado. Into the dealer at least 4 times-said corroded ground wire. Never did get it fixed long term. Waranty was up quick with my mileage at that time. Warning is still on, but truck still performs as it should, but is slow to engage 4WD and must shut off truck to disengage 4WDwhen it's in the Autotrack mode.
My 2015 is good and my 2017 HD is good too, fingers crossed!!
Edited by Ian Pritchard (Hydroguy8)
  • 2 years later...
I also have the same issue." Service 4WD" for  new 2019 GMC sierra  truck .
Comes on  intermittently .
Went into dealer  approx. 3 weeks ago.
Told me they had to order a new actuator.( was not moving when  4WD selected)
None in stock.
Dealer said GMC has to make  a new one?
Still waiting.
2019 2500 hd service 4wd dealer replaced the actuator transfer case module transfer case wire harness and the fuse block still getting the service 4wd light intermittently
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 291 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
