Clunk/grab in tranny or rear end. Check engine light on now. Thoughts?
So I noticed when changing my oil 2 weeks ago my rear tranny seal was seeping. Been checking the fluid and it's still at normal levels. Once last week and then this morning I had a hard clunk/grab when going about 50 mph, letting off to keep distance from car in front, and when I got back on it, it happened. Tranny is shifting normally. But now my check engine light is on. Just rolled 62k the other day. Thoughts?
I'll also add that I wrecked it 1.5 years ago and got a full frame replacement..so it was tore down and put back together. 35k on it since. I also run 285/65/18 Toyo AT2 tires.
What he said......if you don't have a reader go to autozone and have them pull it for you. Its your best place to start.
Was it totaled? why was the frame replaced?
Yeah I'm gonna go to autozone to see what comes up. It could be a coil.. I remember yesterday on 1 startup it didn't start normally. So it could be cutting out while driving. my cousin had a ignition coil go in his '14. Not covered by warranty so $300.
And no it wasn't totaled...just 27k in repairs after the adjuster screwed up on his initial assessment in which he failed to notice the bent frame. So he gave them the go-ahead to tear down and that's when the shop saw the frame...no insurance company would pay a shop to tear down, then put back together to total it..
Suggestion, take it in for maintenance...:-)
Took it to the dealer and they said the code is for the throttle body. $300 something to replace. Not sure if this is truly the issue or not. I get a violent shake at times at 74-75 mph on the highway when it switches between v4 and v8. But it's not consistent, doesn't happen all the time. But when it happens it feels like the motor is lugging, like losing power. I also get a very rough idle at times at intersections. So it could be the throttle body..who knows.
powertrain warranty until 100k...shouldn't cost you a dime to fix a check engine light
Throttle body isn't covered by powertrain..it falls under the 50k emissions warranty. And I'm at 62k. Electrical stuff like coils are also not covered under powertrain FYI. If you read the warranties you can see that the powertrain doesn't cover a whole lot..
  • 2 months later...
im not sure if that year was direct injection but maybe try running some GDI intake valve cleaner through the air intake after the maf. if it is direct injection there could be carbon buildup since fuel doesnt run down the valves
The trans sound normal, or should I say normal for these trucks. At 62K I would say your at the point of the common carbon build up known to DI motors. Some say high revs from time to time keep it at bay other insist it must be chemically cleaned. CDC makes a decent MAF cleaner and intake cleaner to try first.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 413 Guests (See full list)
