2014 chevy 2500hd
2014 chevy 2500hd 4x4 Whats the best upgraded upper intermediate steering shaft to purchase? I done with the steering rattle!
OEM if you think that's what it is, but intermediate steering shafts don't really go bad on the 2007-2014 trucks. Typically the bearings in the upper steering column go bad and quite often.
How do check or replace them?
