What are your thoughts
2tone06ss
What's up guys. Got T Boned on Thursday. It's at the body shop now. Insurance company is coming out tomorrow. You guys think it's totaled? Guy got me at the frame rail too. c7a42cf08d78e9c4c87d4b2aab0c1aa4.jpgaef396d378cf3ff6ddeb6632a8fdcbd1.jpga3e45eceef48bb80a62ae22750e1d5e6.jpg6acbc5361b6bcc23c4784e81b28877b2.jpg6bd3ccd5bf9b91a8f5ca5a75c78255a3.jpg
I wouldn't trust that frame.
The structural integrity of the vehicle can be fixed but the chances of your insurance company to be will to pay out as much as the body shop will need is unlikely.
If it's going to be over 20 grand I bet they will write it off.
Also have to consider what got shifted, if the engine moved from its original position there could be more to fix then what you see.
How are you after the crash?
Thanks for the reply. I'm actually good. Walked away unharmed. Got lucky. Not a scratch on me.
That's good to hear. Have you gone to the doctor?
After you get in a car crash that you aren't at fault for the other persons insurance will cover for a bunch of benefits.
My parents got a orthopedic mattress for no cost. Their insurance covered it under cost of damages
I would get checked out, my grandmother got in a crash and said she was fine about 3 days later they found that she had Traumatic injury of the bladder.
Sent from my iPhone using Tapatalk[/
Wow. I didn't goto any doctors. I actually went to work the very next day.
You're a true man lol I would of took at least a day maybe a week, month if I could
ame="John Boucher" post="2022936" timestamp="1502637639"]
[emoji23][emoji23]
Truck took the hit well, but even if Jesus ran a body shop, even after a good hit it will never be the same. You can replace bits, but metal stretches
Depends on year, and value. If it is 2014+ and only has that body work and replacing a frame, it won't be totaled. I hit a pole in a 2014 and had to have the frame replaced and it wasn't totaled. Best of luck.
You pleased with that?
I actually am happy only because I still owe on it. Have over a year of payments into her and really didn't want to start over.
That is a very good point, you never get your money back.
    • 286,740 Mile Services   8/6/2026   New AC Compressor. Refrigerant oil and dye, evacuate and charge system.  New exhaust system from cat back.  New Iridium plugs plus replace #3 coil Repair/rewire headlamp wiring (passenger side) and replace all forward bulbs. Polish lenses of both assemblies.  Pull rear rotors, clean and adjust parking assembly. Inspect, clean and grease front calipers. Check pads and shoes.  4 wheel power bleed of brake system. Dot 4 Reset idle speed 50 rpm higher New Serpentine belt.    Will need new pads in the rear in about 5K more miles.    Tax Title and License out the door just short of a grand.    AC clutch had bitten the dust. 1 year warranty on the pick and save replacement. Thing will make a Polar Bear cry Uncle.  He spent quite some time on the wiring. It was in the harness and he does nothing half. I got off cheap. I have considerable more light down the road. Sylvania Silver Star replacements.  Gas seal between the porcelain and shell of plug #3 was blown, cooked the coil. That was the cold miss.  Love the new exhaust. I can sneak into the neighborhood again.    This was one of her bigger bills and still way cheaper than a payment even given the oil consumption. This thing cost me under a hundred a month in repairs and normal routine costs. What is my incentive to replace it? 🤔
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
