285/65R20 BFG KO2
ShortMag
Fit with some minor work
Truck is 2014 Denali 6.2 Z71 (3.42 6 speed)
2.25" Readylift up front
3" block in back
After 57,000 miles the 285/60R20 Duratracs I've had since day 1 were loud and choppy (great tire, by the way)
Local 4 Wheel Drive store did the install of the bigger KO2s
Passenger side just needed the wheel well liner pinned back
Driver side needed some minor fender bending and then liner pinned back. It's so minor I can't even tell what they did
Now I've got zero rub
Tires are much quieter. Can definitely feel bigger size both in height of truck as well as acceleration (though only 3lbs heavier and an inch taller - but I can feel it). So both some good and bad in that
Tires seem to run a little narrow as they don't look as wide as the Duratracs even though both are spec'd at 285 width
Will try to get some pics up soon
So far very happy.
It would be close but may have even been able to fit the 35x11.5 Ridge Grapplers but I didn't want to chance it and didn't have all day to do test fits
3" block in back
So far very happy.
Seems to me so the BFG'S I've had run narrow. Good Years seem to run run a little wider then average.
Sent from my E6810 using Tapatalk
