Upper control arm torque spec
Two design bolts. If its the first design bolt, where both cams are separate from the bolt, the nut spec is 140 ft.lbs. The second design bolt has one cam attached to the bolt at the bolt head. That nut is 77 ft.lbs.
The NEW design bolt (a) is slotted, does NOT have a removable adjust cam, and measures 102 mm (4 in).
The OLD design bolt (b) is flat down the entire length of one side, has a removable adjust cam, and measures 110 mm (4.3 in).
Upper Ball joint nut is 37 ft.lbs. first pass, second pass is 90-110 degrees.
Is this the upper and lower ball joint TQ?
2015 z71 silverado
2015 z71 silverado
No. OP was looking for specs for his 2016 upper arms and that's what those are above.
Lower joint is 37 ft.lbs. first pass, 125-135 degrees second pass.
Thank you sir
