6 speed: metallic sound when it shifts
2017 GMC Sierra 5.3L w/ the 6 speed. If I'm driving with the windows down, I can hear a low-volume metallic shrieking sound whenever a gear change is initiated. The sound seems to come right when it's clutching out (these things have clutches, right?) of the old gear before entering the new one. Anyone had this happen, or am I special?
Dave
Sounds like I'm special. Off to the dealer. I wonder if this'll be a "normal characteristic of the truck."
