Chevrolet Tahoe
What year Tahoe??? 2 wheel, 4 wheel drive? Are you referring to an auto or stick trans??? Need a story behind this not going in to low gear. Does it engage in in other gear positions???
Put it into second or third or fourth and see if it will move. The forward apply band on one of my vans busted and would not move with the selector in 1st, but in second it would grudgingly go and then shift to second and stay there.
More details, please. How many miles, what's the service history on the transmission, have there been any issues you've noticed prior to this?
Need help my Tahoe will not shit into first gear. What should I do
I don't think you need to worry about it man, your rig is not supposed to "shit" in any gear.
As for the actual problem that your experiencing, there is not a lot you can do. Automatic or manual >>> check the fluid level, and then check your shift linkage. If one of those is not the problem, then you need a mechanic. (Preferably an honest one)
Oh, one other thing. Assuming the fluid and linage are OK, and its a manual trans, try this:
With the engine off, try putting it into reverse, and then into first. If that doesn't work, try rolling the vehicle a few inches forward or backwards and try to put it into first gear again. Beyond that, I don't think there are any other universal transmission tips.
There may be a specific problem with your exact model of transmission, but you are the only one that knows what type of transmission you have, so all I can offer is generic tips about transmissions in general.
:rollin:
Sounds like at a minimum, valve body pistons might be stuck with "chit" from what he is describing??? Take it to a "good trans mechanic".
